1 - 4 of 4 Posts
The best thing you can do to limit work loss is to set your save increment to 3 minutes. You can do this through the config routine. When shutting down, make sure to close the console before shutting Windows down. If that doesn't work for you, try the graphical version. That has a quit option which may help.
I tried the graphical version . when I open 3D games , each 5 seconds one time i return back to [email protected] window . look at my last loosed WU log :
[15:06:05] Completed 660000 out of 3000000 steps (22)
[15:26:51] Writing local files
[15:26:51] Completed 690000 out of 3000000 steps (23)
[15:40:16] CoreStatus = 1 (1)
[15:40:16] Client-core communications error: ERROR 0x1
[15:40:16] Deleting current work unit & continuing...
when I open the console again , i must download a new WU
I believe that is a known problem with the graphical client. All you can do is turn off folding when you play games.
1 - 4 of 4 Posts
