1 - 4 of 4 Posts
I think this problem is about my OS. That's why i posted in this section.<br><br>
I overclock my video card by using coolbits. I know the card has no problems with the overclocked settings because i also ran Ati Tool before. Anyways i set windows to apply these settings at start-up and after the restart card frequencies goes back to stock settings.<br><br>
Windows is doing the same thing for mouse configurations. I set the pointer speed to higher, apply it and restart. It goes back to previous speed.<br><br>
I did some configurations after the fresh Windows install, i think i messed up somewhere. I used these 2 guides but didn't apply all of them :<br><a href="http://www.overclock.net/windows/9836-xp-definitive-performance-tweaking-guide.html" target="_blank">http://www.overclock.net/windows/983...ing-guide.html</a><br><a href="http://www.overclock.net/faqs/36430-info-ultimate-windows-xp-optimizer-guide.html" target="_blank">http://www.overclock.net/faqs/36430-...zer-guide.html</a><br><br>
Thank you....
Administrator
This should fix your problem : <br />
<br />
CONTINUOUS PERFORMANCE: : To ensure that Windows XP performs at its best all the time you can use the System file checker to locate any missing or damaged system files and replace them. Click on ''Start'' ''Run'' and type exactly WITHOUT quotation marks ''sfc /scannow'' and press ''Enter''.The windows file protection monitor will now scan your entire system for missing or damaged files.Keep your original Windows XP CD at hand as you may be asked for it to replace any missing or damaged files. Other commands that can be used for this step are: <br />
<br />
System File Checker Utility (Scan Immediately) sfc /scannow <br />
System File Checker Utility (Scan Once At Next Boot) sfc /scanonce <br />
System File Checker Utility (Scan On Every Boot) sfc /scanboot <br />
System File Checker Utility (Return to Default Setting) sfc /revert <br />
System File Checker Utility (Purge File Cache) sfc /purgecache <br />
System File Checker Utility (Set Cache Size to size x) sfc /cachesize=x<br />
<br />
If not i would Install Windows again but whil in windows and selcet Upgrade in the install menu as that will perform a repair install.
Administrator
<tr>
<div>
Originally Posted by <strong>3xtr3m3</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1389374#post1389374" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Thanks Kim, will try !</div>
</td>
</tr>
</table>
</div>Wahey yep thats me..So how did it go ?
1 - 4 of 4 Posts
