1 - 3 of 3 Posts
im not really sure what it is or if it rly is a problem but whenever i start my computer, windows acts pretty funny. sometimes iif i open Internet explorer like 5 seconds after i get to my desktop, IE will not open for a few minutes. other times it will open and then will be not responding. then when i try to close the window or go to the ctrl alt del screen, it will take a few minutes to open. usually the problem just goes away after a few minutes and everything responds at normal speeds but others, it gives me a message saying windows is not responding and i need to restart. does anyone know what this could be caused from?
Do the usual, virus/malware scan, CCleaner registry sweep, disable unused startup progs, defrag. Disable any dodgy IE addons. Failing all that, reinstall windows. Failing THAT, get an SSD
1 - 3 of 3 Posts
