Hi dear fellows,
First of all, please note that I will talk about a laptop problem, not about desktop/builds. I have a laptop with a HM76 Chipset and I've upgrade from an i5 3210M to an i7 3630QM, so perfectly compatible. I also bought an additional stick of 8GB RAM with dual voltage of 1.35V and 1.5V, from Crucial (according to the information on the Crucial's website, I think they are both running at 1.5V).
It was everything OK and I was very happy with the big upgrade. However, when I decide to do a memory test with memtest86 and memtest86+ I got many errors, but just in the latest tests, and always after 1h of test (with Windows diagnostic tool I had no errors). So I did some tests with memtest86 to know which RAM stick was damaged and I came to the conclusion that they are both good but Slot 1 don't. If I put any stick of RAM in the Slot 1 I have errors in memtest86 and BSoD in Prime95. If I just use the Slot 2 I have no problems. I don't know if I already had this problem in Slot 1 before the upgrade, because I never did a scan memtest86, or if by some (very strange) reason, I have damaged the motherboard/Slot 1 with this CPU and RAM upgrade.
But, what I would like to ask is if there is any problem of ignoring this damage in Slot 1 and use only the Slot 2 with the limited 8GB RAM, or if it is probable that the motherboard will show more problems/errors/damages in the future.. ?? Should I by another motherboard, or I will not have bigger problems than an unusable Slot of RAM?
Thank you in advance for your time and help,
I wish you all a great week!
Best regards.
Best regards.
