1 - 18 of 18 Posts
Originally Posted by alexisd
I just receive my system yesterday ,the problem is with the 6800 gs sli cards.some black's lines at the games.some help here please?
that would be your PSU... time for a new one
I'm guessing your using the one from your case?
hesa right its stibilaty problems id say get a ocz powerstream 620W that should solve your problems
its the lack of power getting to the videocards whats the 12V amps your psu is rated for?
there should be one around 18A rear that
yes it your psu u need at least 20A if you are running 2 videocards in sli or u get stabilty problems (those lines)
I can belived but goin to work around that,Thanks
work around it... oh boy, your running yourself into more trouble
Black lines? top and bottom? or middle of the screen? if its top and the bottom then its ur resolution, if its not the resolution then its the power supply try using 2 different connections, instead of having 2 connections from the psu going to the 2 card use 2 connections isntead.
Do the black lines have a green square on them? Try this and see if this is problem. You may have the problem this guy did.
http://www.overclock.net/nvidia/7626...tml#post780754
Es
lmao u could have a 1000W psu if the 12V rail has low amps like yours then ur ****ed eather way u go
They don't sell a 620W, but they sell a 520W and a 600W. The 600W has been known to have problems. I haven't heard much negative about the 520W, but they're both made by the same manufacturer. (ToPower)
http://www.tomshardware.com/2005/07/...st/page21.html
1 - 18 of 18 Posts
