1 - 7 of 7 Posts
Hey OCN,
My problem is, I can't push my processor past 3.5GHz, no matter what combinations of FSB and multi's I try. I had it get as far as the Vista boot logo, but then blue screened on me. That was with a 3.8GHz clock. Any suggestions? I've attached pictures of temps, the CPU-Z, all while running Prime95 on it. Any help would be much appreciated!
I had to push my vcore to 1.375 in bios 1.35 idle 1.36 load to get mine stable at 350x10.5. Now I am stuck there because I don't want to raise my vcore anymore than I have. My ram is faster than yours though. What do you have your memory divider set at?
generally, e7x00 needs more voltages than the e8x00 series. an e8400 only needs 1.29-1.34 to hit 4.0 whereas an e7x00 need about 1.38-1.42 to hit 4.0. believe me, if you want to get 3.8+, you'll need to bump ur vcore 1.38+ provided you have a motherboard that has less vdroop
1 - 7 of 7 Posts
