SPECS:
Intel Quad Core i7-2600k 3.40 GHz 8mb L3 Cache
Gigabyte GA-Z77-D3H
Cooler Master Silent Pro M 850w
DDR3 8GB 1600MHz
Win7 64bit
ADATA SSD 120gb + (250 + 150gb HDDs)
Geforce GTS 250 + XFX AMD Radeon HD7970
Upon removing my previous graphic card, a Geforce GTS 250, I proceeded to upgrade my PSU and bringing my computer to the specifications I listed above, then proceeded to install the Radeon 7970 graphics card. Testing the new hardware resulted in a black screen, after 4 hours of tedious tinkering and deletion of old drivers, I managed to use the on-board graphics to download drivers individually and somehow it ended up working, somehow....
The graphics card worked for two days just fine, I tested it on borderlands 2, team fortress 2, and deus ex: human revolution, I did shut down the computer numerous time so it was not two days continuously however. While simply browsing the web on the third day my screen suddenly went black and since then has not recovered no matter how long I leave the computer off for, how much time I wait or what I try. I am at wit`s end and have no clue what to do next, I put my old graphic card back in and everything worked just fine. I checked the bios version and it seems the only higher version of the bios available for my motherboard is 19g instead of 18, and 19g is labeled as a "Beta" version in testing, I doubt the bios is the problem but if other people say otherwise then I might try it.
I did reset my bios to factory defaults or CMOS or whatever it's called, did make sure that it was reading from the pci slot as well again. I tried moving cables around into different slots because it is a modular power supply, but those cables worked just fine for my GTS so. I also tried using an hdmi(vga) to dvi(monitor) cable and dvi(vga) to dvi(monitor) cable to see if that was the problem, but the HDMI to DVI worked just fine till it died before so....
I sent a support ticket to XFX, but I haven't a clue when I'm going to get a response.
The card was bought from Tiger Direct the actual, physical retail store. Walked in looking for a 7870 by HIS which they didn't have and bought the XFX 7970 since it was the best model they did have.
Thanks in advance to any and all help offered. If I can't figure this out soon I'll have to RMA it.
Gigabyte GA-Z77-D3H
DDR3 8GB 1600MHz
Win7 64bit
