1 - 16 of 16 Posts
Hi guys! My computer is..<br />
<br />
E6600 core2duo <br />
Asus P5B<br />
Geforce 7950gx2<br />
2gb ram<br />
Seasonic S12 600W<br />
and a Cooler Master chassie..<br />
<br />
Now to the problem, I cant find any USB device, just says its problem finding USB. And the computer cant find any sounddevice(on the motherboard) . Anyone here with problem with this motherboard? i have all the latest drivers and even tried flashing BIOS, but i dosnt get it to work, i have read somthing about flashing BIOS with another processor!? Pls help me!!!<br />
<br />
Excuse my poor english!
Did you replace the MoBo without re-installing Windows?
Erik... go to Start>My computer> right click> Properties>Hardware> Device Manager> are there any yellow Exclamation Points (!) at your Universal Serial Bus hardware locations? ( Your English is excellent, by the way).
I remember when......
What OS are you using? <br />
<br />
It should at least see your USB ports as low speed hubs until you have the Intel INF chipset drivers installed (use the ones off the Intel site, not the ones on the CD).<br />
<br />
<a href="http://downloadfinder.intel.com/scripts-df-external/Product_Filter.aspx?ProductID=816" target="_blank">http://downloadfinder.intel.com/scri...?ProductID=816</a>
<tr>
<div>
Originally Posted by <strong>Erik_kga</strong>
</div>
<div style="font-style:italic">Hi guys! My computer is..<br />
<br />
Asus P5B<br />
2gb ram<br />
<br />
<br />
Excuse my poor english!</div>
</td>
</tr>
</table>
</div>Stupid question but did you install all of the motherboard driver files that came on the CD with the mobo <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>Sdumper</strong>
</div>
<div style="font-style:italic">Stupid question but did you install all of the motherboard driver files that came on the CD with the mobo <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><br />
My question also....it happens (to me) <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" />
Discussion Starter #7
Thanks for all the answers! <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
Yea I just bought the whole computer, I have even tried to format and reinstalling windows a cupple of times. No result. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"> . I can say that I tried a Asus P5N 32 SLi Deluxe mobo at first but then the computer wouldnt start at all! <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"> Yea I have installed all the mobo drivers but not the soundmax(audiodevice) cuz i want work <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"> . I also download all the latest drivers from each manifactures webpages but i want work! I dont have the computer home right now so i cant try so much, I have turned it in to a computerdealer but it seams he dosnt know a ****! <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"> I just want my brand new pc at home and have it to work! <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"> . So guys cant it mabe be the powersupply? (Seasonic S12 600W) ? Or what do you thinkl? The dealr talking **** about the chassie maybe short circuit the mobo? I just hink that sounds weird?<br><br>
I have tried posting same problem on a Swedish computer site, but theres no answers! Thanks guys u are awesome! (Atleast u try to help me) <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
The PSU is not the problem. The Seasonic is a beast. Usb cables plugged in properly? I'm stumped if nothing said so far has helped..
Administrator
<div>Originally Posted by <strong>NrGx</strong></div>
<div style="font-style:italic;">The PSU is not the problem. The Seasonic is a beast. Usb cables plugged in properly? I'm stumped if nothing said so far has helped..</div>
</td>
</tr></table></div>
Not always correct now in this case it wouldnt be the PSU, However just becasue it looks good or is of a good brand doesnt mean it may not be an issue.<br><br>
Anyway. Have you made sure that you installed the USB drivers from the motherboard driver cd you should have been supplied ?.<br><br>
Have you also performed a Windows update found here :<a href="http://windowsupdate.microsoft.com/" target="_blank">http://windowsupdate.microsoft.com/</a><br><br>
Anotherthing would be to RESET your CMOS. To do this remove the little battery from the motherboard for 2mins and then put it back in. This will cause the BIOS to reset to its factory defualts and re-recognise all hardware attached to the system.
Discussion Starter #10
</td>
</tr></table></div>
<br>
Ah ok! .. Yea the USB is checked so many times u would be frightened! <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> ... The intergraded usb on the mobo dosn't work either! :/ .. Can it really be so stupid that chassie make all this trouble?
Discussion Starter #12
<div>Originally Posted by <strong>ENTERPRISE1701</strong></div>
<div style="font-style:italic;">Sometimes the CASE will earth the motherboard and not make some things work. I would try the motherbaord outside of the case.</div>
</td>
</tr></table></div>
Ok so that can be so.. I thought it sounded weird. Ok I will try the mobo outside the case, when I get a new mobo, because this I have now dont work outside but i maybe so that its allready damage by the case! <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
Administrator
I doubt there would have been extensive enough damage however some parts of the motherbaord are sensitive and your USB's may have been damaged. I would personally RMA that motherboard and get your money back or a replacement.
Discussion Starter #14
<tr>
<div>
</div>
<div style="font-style:italic">I doubt there would have been extensive enough damage however some parts of the motherbaord are sensitive and your USB's may have been damaged. I would personally RMA that motherboard and get your money back or a replacement.</div>
</td>
</tr>
</table>
</div>Hmm .. I mean the first mobo Asus P5N 32SLI Deluxe wouldnt start at all, the case fans turned on but the mobo just were dead. I just want to know where the problem is, It must be the case or the PSU(power supply?) .. Thanks for all help! <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I would still want to know what OS you are trying to use. I ask because some of your problems sound like they are caused by using XP without SP2.<br />
<br />
However, having 2 different boards give such trouble in this way....I hate to say it, but it may be an installation error. Definatly try to run it out of the case, place it on the anti-static bag on top of a piece of carboard, see if it works that way as was suggested.<br />
<br />
Make sure you used all the proper standoffs when moutning it int he case...make sure you plugged in all the power connectors tot he baord, make sure there is no physical damage to the board.<br />
<br />
You may need to RMA it and it's just bad luck, but if the replacement is the same, there is something else going on.
Are you using the same RAM? RAM conflicts can cause wierd issues such as those. Have you tried switching DIMM positions? Or only using one stick? I had a Abit Ic7 that one day, stopped working due to RAM conflict. When I replaced my Mushkin, w/ Corsair X, I had no problems and the board has been working ever since. Keep in mind, that was one year after I built the entire system, before it caused any problems. <br />
*You replaced the mobo....and your problem still exists-> you still have bad hardware. Just continue to swap out components one by one.....if you have extras handy that is.
1 - 16 of 16 Posts
