1 - 20 of 20 Posts
When i start up i get nothing on my monitor, and its a brand new mobo
1 gb ram
40 gb and 1 80 gb maxtor
350w encer psu
gigabyte Ga-k8n51gmf-rh
and cpu newcasle 3400+ 754
but heres my dilemma, i have a ground pin missing on my cpu, could this be the problem as from looking into the pin it is a ground one
any help would be appreciated
Thanks - Mark
Discussion Starter #5
Yea it is actually on the processor, and i cant get into the bios at all ithink the pin is b29 or along them lines right on the edge
Does the fans spin and everything? Any beeps? Do you get any display on the monitor?
Discussion Starter #7
nothing displayed on the monitor, no beeps (prehaps it not having a beeder might cause that
) and all lights and fans are on
Well, does things like the hard drive wur? Also plug the beeper in, the code can tell us what problem it might have.
Discussion Starter #9
yup i belive so and even if they didnt i would be able to get into the bios + i dont have a beeper
Well if it is a ground pin which is missing on the cpu the pc should have booted , but if it isnt it may be causing this, to be sure i would insert another cpu and check if it works
Offcourse the problem might not be the cpu ,
first try reseting the bios
then remove all components except cpu-ram, if u still get a problem here try using only one ram chip. then one by one insert the components on trying to find which one is causing the havoc
Discussion Starter #13
nothing at all! still nothing coming up on monitor but sounds well, this just cpu and ram still no responce on screen
this means no signal from the mobo which most probably means that either onboard is not selected or you have a dead mobo try look for a jumper on the motherboard which selects it , or look at the manual of the mobo , if you tell me the motherboard i might be able to help you out
1 - 20 of 20 Posts
