1 - 4 of 4 Posts
Finally got my motherboard in today and i'm trying to install the Megahalem heatsinking onto the motherboard... The problem is I can't seem to get the backplate screws to go threw the motherboard holes. It's not that they aren't alligned, the problem is that the screws aren't long enough to go through the holes. It seems that the rubber spacer on the backplate are preventing the screws to go through, so would it be possible to use the backplate without the rubber mount?
1 - 4 of 4 Posts
