What I have.
Corsair TX650
GIGABYTE Z77x-UD3H
I7 3770K
MSI GTX 660TI OC
Kraken X60 cpu cooler
I have 2 problems that Im assuming are being caused by my card
So far these only happen when Im playing or go to play BF3. Dont have any other games installed yet. I did play SimCity beta for about 30min and didnt seem to have a problem.
1) I get this DirectX error. Device Hung due to badly formed commands. I did some digging and I read in several places that if people overclocked their GPU, it would fix this
However, when I over clock my GPU(I used MSI afterburner), even if I up the settings a hair or +1, I then get a Flash Plugin disabled or blocked message in both FireFox and IE and Battlelog tells me I have to install a update, even if I install it, the message doesn't go away
Now, I don't normally overclock my CPU or GPU. MY prior comp had a first gen I5 12gb ram and a GTX 460 set at stock specs and I NEVER had problems. I spend $1500 on this comp, and I cant play BF3 for more then 30min without a problem, or sometimes I cant even get the game to load because of the flash plugin issue.
Ive had this computer a full week now and Im already fed up with this, and have no clue what to do or where to really start, as the research I have done, has pointed me in every direction looking at ever part of the PC, from the PSU to the ram, to the mobo, to the CPU
Does anyone have any suggestions?
Also ill note this Graphics card has the stupid coil whine.
Corsair TX650
GIGABYTE Z77x-UD3H
I7 3770K
MSI GTX 660TI OC
