Hello all.
I've been using Fedora since FC4 and haven't really encountered any problem like this before. I'm thinking it's hardware related, most likely video card.
I had F9 but figured since I upgraded hardware, I'd check out F10. Installed fine, grub loaded and boot into the new kernel fine. Kernel loads and I'm stuck at a black screen with a blinking cursor.
I'm assuming this is a problem with X either not finding the driver for this VGA, or Xorg.conf not configured correctly, and something I'd have to do via command line by booting with the install disk. The 200 series cards are supported, and I usually have to compile the driver anyway, but I've at least been able to get into the gui first.
It's the x86-64 version. Anyone with similar hardware using Fedora had a problem?
