1 - 5 of 5 Posts
The assignment is to describe a process be it manufacturing, or how the human body works. It is due tomorrow morning and I haven't started :/
It does not have to be a difficult topic...nor do I want it to be.
Document 1 Process Analysis Assignment
Use the writing criteria in Ch. 11 to compose an effective process analysis. You can choose your topic. Some possible topics include how a hybrid car works, how viruses attack our bodies, how email messages are transmitted, and how metal detectors work (326).
Your process analysis must include
a title
introduction
discussion
conclusion
at least one graphic
In the introduction, you should clarify who the audience is and what the purpose is, and list any necessary tools, materials, or supplies. In the discussion, break down the process into chronological steps, and state them using photographic language. Use white space and highlighting effectively.
Bring three copies of your draft for the peer review.
I was going to suggest the mechanics of firing a gun.
Theres a lot of motion and parts so its easy to write
Reactions: austinb324
Discussion Starter #5
Originally Posted by spartacus View Post
I was going to suggest how aluminum pop cans are manufactured.... but BitTorrent works too!
Great ideas. I will keep them for later. This was just the first of several assignments.
+Rep
1 - 5 of 5 Posts
