1 - 3 of 3 Posts
Processor overclocked after when the computer starts up and see the computer in components data.
Then the crash and the machine starts up again all the time.
If the original BIOS settings the computer starts normally.
Processor: E8600
Motherboard: Foxconn blackops
What can I do that's computer starts up normally after overclocked?
bad english...
It is because your overclock is unstable.
It could be a variety of reasons though, not enough voltage, too much heat, etc.
I haven't personally owned an E8600 cpu, so I can't give you specific advice into your particular problem and stabilizing that oc.
You could start by listing what BIOS settings you are using.
1 - 3 of 3 Posts
