As we would also like to hear your paise and complaints about specific products. We will be opening up several threads where you can express your opinions.
This one is about our new EK-Vardar Fx-120 series.
FYI, a bit of technical info
Also, currently we are running a Vardar + Radiator Giveaway. All you need to do is to head out to http://www.ekwb.com and sign up for our newsletter. We promise we will not spam you guys! If you are already signed up you might win it without moving a finger
- unlike other general-purpose computer cooling fans, the EK-Vardar family of fans is built specifically for computer liquid cooling systems, namely radiator cooling. The 7-fin fan blade design is optimized for high pressure operation while maintaining the low noise profile throughout the whole operation range of the fan.
- High-quality motor and bearing assembly - Proven electrical design, actively cooled motor windings and Double Ball bearing with 50.000 hours lifespan (MTBF) ensures uninterrupted operation for years to come. Phase-width modulation (PWM) fan speed allows performance on demand.
- Sealed-edge fan casing - The classic, yet effective square shape of the fan casing ensures optimal performance in either pull- (suction) or push (pressure) regime without hydraulic losses thus ensuring optimal cooling capacity of your liquid cooling radiators.
