Which program should i use when overklocking an radeon 9200 se card,and how much is prefered to high it up?
A good program is ATITool. Open it up and then select "Find Max Memory" and leave for around 30 mins artifact free. The select "Find Max Memory" and leave for between 30mins and an hour, artifact free.
Then download Radlinker and set the clock speeds to that you have just found with ATITool. Radlinker will startup when you boot and change the speeds for you.
i used ATI tool once i selected find max memory, then it went on for a very long time, then the cp just restarted by itself and it had not find any maximum.
