1 - 6 of 6 Posts
You can try Motherboard Monitor; I'm not sure if is will support your MB, but I use it with mine and get the same readings as my Abit software. Hope this helped. By the way, here is the link to a download from Major Geek:
http://www.majorgeeks.com/download.php?det=311
Good luck!
1 - 6 of 6 Posts
