Originally Posted by rabidgnome229 ![]() No primitive datatype can hold that value. You need to create/use a third party BigInteger type class |
Originally Posted by error10 ![]() Why would you multiply two numbers if you didn't intend to use the result? |
int c = 1;
for (int i=0;i<e;i++){
c = (c*m)%n;
#!/usr/bin/env python
import sys
def fib_even():
sum = 0
last = (0, 1)
curr = 0
while sum < 4000000 :
curr = last[0] + last[1]
if not (curr % 2) :
sum += curr
last = (last[1], curr)
else:
return sum-curr
def get_fact(fact, num):
if not num in fact :
fact[num] = num * get_fact(fact, num-1)
return fact[num]
def factorial_sum(limit):
fact = {0 : 1, 1 : 1, 2 : 2}
r = xrange(3, limit+1)
for n in r:
num = n
sum = get_fact(fact, n % 10)
while n / 10 != 0 :
n /= 10;
f = get_fact(fact, n % 10)
sum += f
else:
if sum == num :
print " ", num, " is a solution"
sum = fib_even()
print "The sum of all even fibonacci number such that the sum is less than 4,000,000 is", sum
if len(sys.argv) < 2 :
factorial_sum(1000000)
else :
factorial_sum(int(sys.argv[1]))
import sys
##### function definitions #####
def is_prime(p, n) :
for d in p :
if (n/d)*d == n :
return False
else :
return True
##### begin main #####
# parse command line arguments
limit = 1000000
else :
limit = int(sys.argv[1])
# seed list of primes
p = [2]
solution = []
# generate all primes in range
for n in r :
if is_prime(p, n) :
p = p + [n]
# iterate through all primes
for n in p :
# convert to a list of digits
s = str(n)
r = xrange(1, len(s))
valid = True
# check all rotations of the prime
for i in r :
rs = s[i:len(l)] + s[0:i]
if not int(rs) in p :
valid = False
else :
if valid == True :
solution = solution + [n]
for s in solution :
print s
[CODE]
<?php
$handle = fopen("roman.txt", "r");
$numbers_file = fread($handle, filesize("roman.txt"));
fclose($handle);
$numbers_array = explode("\
", $numbers_file);
foreach($numbers_array as $number) {
$number = preg_replace("/[\
]/", "", $number);
print($number . ": " . strlen($number) . " characters beforehand.\
$old = strlen($number);
$number = str_replace("IIIII", "V", $number);
$number = str_replace("IIII", "IV", $number);
$number = str_replace("VIV", "IX", $number);
$number = str_replace("VV", "X", $number);
$number = str_replace("XXXXX", "L", $number);
$number = str_replace("XXXX", "XL", $number);
$number = str_replace("LXL", "XC", $number);
$number = str_replace("LL", "C", $number);
$number = str_replace("CCCCC", "D", $number);
$number = str_replace("CCCC", "CD", $number);
$number = str_replace("DCD", "CM", $number);
$number = str_replace("DD", "M", $number);
print($number . ": ". strlen($number) . " characters afterward.\
print("There were " . ($old - strlen($number)) . " characters saved.\
Originally Posted by ToastedZergling ![]() I have given the #10 Crackless Wall Puzzle using javascript, but I'm having a problem calculating the larger values. I can get up to W (18, 5) = 7958, but if I go much further up on the first parameter I get array out of bounds errors and other ugly messages. Does anyone think they could lend a spare set of eyes to see how I can improve this? I'm thinking I will have to modify the permute function, which I didn't write to begin with =( Sad face at modifying other people's code, I like it when their work can just be a big black box. |
