1 - 2 of 2 Posts
Hello Hello, I'm not sure if this only applies to computer programming but I have a question in trying to program a TI-83 plus.
So I have this formula:
Y = ((height + distance) x 1.25) x (2 - power) +/- wind)
Y is the final result of power.
I've been able to program everything up till the last "+/- wind," part.
There is 2 options to that part. If the wind is against me, then I have to take the wind value and divide it by 3 and add it to Y.
If the wind is a tailwind, then I have to take the wind value and then divide by 6 and subtract it from Y.
How would I go about adding the two options into the TI-83 plus? Should I use the If and Then command?
Any help would be appreciative!
Initally store the wind value (+/-) into let's say W.
whatever -> W
If (W>0) tailwind...right? if not it's <
Then
W*-2 -> W
End
W/6 -> W
Y+W -> Y
That was a complete blurt, make what you can out of it...
1 - 2 of 2 Posts
