5
So after
this thread, i found
this initial design. i have decided that a 5.1 Switch is a must for my set up to toggle between my surround sound system & 5.1 roccat cave headset - which is supercool. i searched all internet & china ebay stock to find something similar with no avail. so...
THERE IS NO 5.1 SWITCH IN THIS WORLD!!!
... since 5.1 headsets becoming popular amongst gamers i thought i might share with OCN some ideas.
this headset got a control unit, so i wanted to find a box that i would stick under it nicely so the switches and sockets are on the side.
i bought the right size box, 3 DPDT switches and 9 female 3.5 audio stereo sockets.
then i got to work. let the photos talk...
Photo number:
1 - holes cut but not straight enough... should have used pilothole.
2 - that box had some unnecesary plastic that had to be removed.
3 - cutting switch holes.
4 - filing.
5 - mess.
TO BE CONTINUED...
