21 - 22 of 22 Posts
Discussion Starter · #22 ·
and a tiny update: I marked off the side panel and started cutting it for this machine and my sig rig... installed a rheobus extreme to control all the fans in the system, and basically cleaned it up a bit more inside.
The 640gb Cav black is in there as the only drive, and everything else is reinstalled. I replaced some of the sheathing with a smaller diameter to hopefully keep everything cleaner in the case, zip-tie-mounted another 120mm fan, and worked a bit on cable management. Pics will be uploaded this afternoon of the progress so far.
21 - 22 of 22 Posts
