About 2 weeks ago, my PSU blew up in my Antec 900 (original model). When I went to go put in my new Corsair TX750W, I got fed up with the cable management of the 900, and ended up getting a Cooler Master Storm Scout. I LOVE this case. But there were still a few things I wanted to change.
You may have seen a few of these mods scattered in other threads already, but now that I'm doing a lot more than I originally thought, I figured I should give this build its own thread. And with no further ado:
List of mods that need to be done:
1. Replace original window with new, clear one
2. Open a few cable management holes for even better routing
3. Make a "false floor" to hide all the unused PSU cables
4. Make a terminal block to get rid of all the molex fan connectors
5. Add another fan into the 5.25" drive bay
6. Sleeve individual wires on the PSU
7. Overall extreme cable management
Table on Contents
1. Case is here!
2. The new window
3. Cut bigger hole for 24-pin cable
4. False floor #1
5. Terminal block for fans
6. Case torn apart/beginnings of cable management
7. All pins removed waiting for sleeving to arrive
8. False floor #2
9. New fan ghetto-modded into the drive bay
10. Fan re-done
11. FINISHED
Table on Contents
1. Case is here!
2. The new window
4. False floor #1
8. False floor #2
10. Fan re-done
11. FINISHED
