1 - 20 of 134 Posts
1/aquabox 5 1/4
1/Aquaero 4.00 USB Fan-Controller, black/white
1/Black Faceplate for Aquaero
2/Aqua Computer Poweradjust USB (with mounting kit)
1/Aquatube G1/4 Delrin black with fittings
1/Black Faceplate for Aquatube
1/Aquabay AT (installation bay for aquatube
12/Blacknoise Noiseblocker Multiframe S-Series M12-S1 51.2 CFM
1/Logisys Dual White 12in. CCFL Light kit
2/SATA II Cable Black 24" 180 to 90 degree connector
1/TIM-Consultants - T-C Grease™ 0098 Thermal Interface Material
1/Floppy Black 18"
2/Feser One F1 Cooling Fluid - UV Black - 1 Liter
2/DD12V-D5 Pump Variable Speed by Laing
2/Feser X-Changer QUAD 480 Extreme Performance Radiator
8/Feser TFC Xtender - Radiator Shroud 120 - BLUE LED
2/A.C. Ryan AcrylPanel 3mm 480x480mm Black
Black Heatshrink 1/2 inch - 5 foot
Custom Cut Length 3/8 Expandable Sleeving - 10 foot
Tygon R3603 7/16 x 5/8" AAC00033 28 Foot
Koolance 62 Line items
also the Koolance Blocks are as followed
2/ VID-NX295
6/ RAM-35,
1 CHC-120-V06
1 CHC-122
1 CPU-340
2 MVR-40
Are you WCing the SB, mosfets and vRegs just because you can? Because they really don't need it.
Looks like it will be a hell of a setup!
Also, I've heard Koolance's new stuff is actually pretty good and the blocks don't have any aluminum in 'em, but I would double check... Chances are you can get some better quality blocks from other manufacturers.
its because i need for the 1000 time i'm in Asia also it's very hot here do you know last night it was 31c also cheaper also rather just get these then go out and buy a new p6t because it's over heated it not like i'm in canada where it snows all the time MCBrown.CA's
I think it's a great idea. Gonna look sweet! Yeah you need the cooling, where I am you need hectic cooling already.
Reactions: nicky.82uk
Discussion Starter · #9 ·
why Koolance because they kick ass when it comes down to i7 blocks also look alot nicer also the gpu blocks are tight also sold the most on the market when it comes down to the Gf295
Discussion Starter · #13 ·
lol cut a long story short i was drilling on the top and the side hinges came of and lost a drill bit not my fault black and deckers fault useing cheap metal for there drills bit's i was sorting out the top for the rad but never mind i hated the wireing for this case takes too long still never looks nice
I lol'd, 31c is nothing mate
. Good luck with your loop nevertheless.
subd
1 - 20 of 134 Posts
