Table of Contents
1. First Post
2. This Post
3. Introduction
4. Sneak Peek of Final Design
5. Final Case Design(Google Sketchup File Attached)
6. Acrylic Arrival
7. Method of Sanding and Polishing
8. First Sleeving Attempt and Acrylic cut with Table Saw
9.Cubes Drilled and Tapped
10. Drilled and Tapped Motherboard Tray
11. Starting the CD/5.25" Drive Cage
12. Starting the Hard Drive Cage
13. Cutting Small Pieces for Custom Acrylic Shrouds
14. Sneak Peek of First Mock-up
15. 4.5" Hole Saw Tests
16. Pieces for Shroud Cut and Shroud Feet Polished
17. Shroud Assembly Begins
18. CR Gives Four Thumbs
19. More Shroud Assembly
20. Shrouds Completed
21. How to: Cutting 4.5" Holes in Acrylic with a Hole Saw
22. More 4.5" Holes Cut in Case Panels
23. Router Tests
24. Router Templates and Interior Routing
25. More Interior Routing
26. Routed I/O Shield Opening and Mock-up
27. Re-Routing Edges and Fixing Mistakes
28. Pump Mount and CCFL Test
29. Mounting CD and HDD cages
30. Cathodes + Radiator =
31. Glimpse of Cable Management Holes Around Motherboard Tray
32. Experiment: Sanding and Polishing a Poorly Routed Edge
33. Cable Management Holes, Reservoir Mounting, Destruction and Repair of Pump Mount
34. Syrillian Gives Approval
35. Dry Mount of Waterblocks, Cutting and Routing Tubing
36. Polishing of Base and Installation of Case Feet
37. Polishing of Left Case Panel
38. Polishing of Rear Case Panel
39. Front Panel Polished and Installed, Outer Case Shell Mock-up
40. Paper Backing Removed from Interior(black) Panels, Another Mock-up
41. More Mock-up Pictures
42. Mock-up that won the May MOTM
43. CD Drops by for a Visit
44. Cathode Holder/Light-Bar Construction Begins
45. First Cathode Holder Nearly Complete
46. Completed UV Light-Bars(lots of good night shots of motherboard/tubing mock-up)
47. Construction of Cable Management Cubes and Adding Supports to the BB Panels
48. CD Faceplate
49. Repairs and Solvent Welding
50. Mock-up with and Closer Look at Light-Bar Holders
51. Faceplate Mounting, Mystery Holes, Polishing, Paper Removal and Mock-up
52. Lapping and Waterblock Installation
53. Custom Scratch Built Light Controller Board
54. LEDs and LED Wheel
55. Pictures of LED Wheel in Action
56. Fan Controller Board, Custom Wiring and Sleeving
57. New(Second) Light Controller Board, LED Wheel Installation
58. Radiator Lighting and Night Shots
59. Beginning Final Assembly
60. Night Pictures after "Final Assembly"
61. Pictures of the Inside of BB(the hidden middle section) and some Day Shots
62. Light Switch, Cathode Installation, Radiator Filter Installation
63. Quick Overclocking
64. GPU Load Temps and 48 Hrs. Prime95 Stable
65. Photo-Shoot
Bill of Materials
1x ASUS 22X DVD Burner with LightScribe Black SATA Model DRW-22B1LT - Retail $27.99
1x EDIMAX EW-7128G PCI Wireless Card - Retail $19.99
1x CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 1066 TWIN2X4096-8500C5D - Retail $59.99 after rebate
1x 120mm Scythe SFF21G S-FLEX™ Case Fan (75.0 CFM/34.0 dBA) $13.99
1x 120mm Yate Loon D12SM-12 Case Fan - Black (70.5 CFM, 33 dBA) $5.95
7x 120mm Plastic Fan Filter - Black $13.93
1x Colored Cast Acrylic Sheet .236" Thick, 12" X 12", Bronze (Same as 8505K91) From McMaster-Carr $7.33
1x Colored Cast Acrylic Sheet .236" Thick, 12" X 12", Gray (Same as 8505K91) From McMaster-Carr $7.33
1x Scythe SFF21F 63 CFM S-FLEX 120mm Quiet FAN by Sony $14.95
1x Black Nylon 1/2in. Barbed Equal Tee Fitting $1.35
2x Bitspower Anti-Vibration Silicon pads - Universal-Mini $7
1x Colored Cast Acrylic Sheet .236" Thick, 12" X 12", Black (Same as 8505K91) $7.33
Plastic/Acrylic Supplies from San Diego Plastics(Most of these are made or sold by Craftics):
Saw Blade, Circular 7.25" P/N 1106064 $56
Corner-Rounding bit 1/4 CED OAL 1-29/32 P/N 42-02 $35.75
Plasticator Bottle 27 GA, 1/2 OZ P/N 1106046 $2.20
Double Edge Upcut Bit OAL 2-1/2 P/N 52-622 $20
Edge Scraper P/N 1106020 $9.76
Weld On #3, Pint P/N 45090240 $12
Arbor Adapter 1/2 P/N 1106053 $4.8
Buffing Kit P/N 1106019 $9.6
Large Buffing Wheel 6 dia x 5/8 hole P/N 1106758 $7.5
Pink Rouge 2lb bar P/N 1106767 $10.12
1x Modular I/O Panel (Brushed ALU) $19.99
2x Elegant Anodized Aluminum Covered Case Feet (4/pkg) - Shiny Gold $13.9
1x A.C. Ryan TWIN Overboost Dual 12" CCFL Light - UV $14.95
1x A.C. Ryan TWIN Overboost Dual 4" CCFL Light - UV $12.95
1x A.C. Ryan AcrylPanelT 5mm - 480x480mm UV Green $19.95
1x Professional Hardware Assortment Pack $9.95
1x Wire Sleeving Kit - Black $7.99
4x Swiftech HydrX Extreme Duty Coolant $11.96
10x 1/2" ID (3/4" OD) Feser Flexible PVC Tubing - UV Acid Green $27.5
2x Swiftech MCW60-R2 GPU Waterblock $93.9
1x Logisys 12" Dual Cold Cathode Kit - Green $5.75
7x Scythe SFF21G 75 CFM S-FLEX 120mm FAN by Sony $91
2x Swiftech MC21 Mosfet Heatsinks for VCore SMC $13
2x Swiftech MC14 BGA Memory Ramsinks w/Thermattach T411 Tape $26.5
1x Feser X-Changer QUAD 480 Extreme Performance Radiator $163.95
6x Breeze Miniature Hose Clamp 7/16 in. to 25/32 in. $2.34
1x Aqua Computer Ball valve internal thread G 1/4 without fittings $6.5
12x 3-pin Male Header $3
6x Swiftech High Flow Fittings 1/4in BSPP thread to 1/2in ID Barb $13.5
1x Creative X-Fi Titanium $84.99
1x Novus #1 Plastic Clean & Shine $6.95
1x Clean-Rite Microfiber Cleaning Towels 12-pack $12.88
2x Silverhill Milled Aluminum Guitar Knob, Pack of 3, Black Anodized $10
4x 120 mm Fan Grill - Chrome $5.96
1x Delrin Vandal Resistant Illuminated Switch Black - 22mm Blue Ring $16.95
1x Delrin Vandal Resistant Illuminated Switch Black - 22mm Green Dot $16.95
4x 25 ohm 3W Pot $15.96
1x Clear Cast Acrylic Rod 1" Diameter $6.45
18x Clear Cast Acrylic Cube 1" Square $22.68
1x Clear Cast Acrylic Sheet .236" Thick, 24" X 48" $48.86
2x Colored Cast Acrylic Sheet .236" Thick, 24" X 36", Gray (Same as 8505K95) $87.82
1x Colored Cast Acrylic Sheet .236" Thick, 24" X 36", Black (Same as 8505K95) $43.91
2x Colored Cast Acrylic Sheet .118" Thick, 24" X 24", Black (Same as 8505K14) $41.08
Updated 5/16/09
Radioshack Heatshrink Tubing and PC Board ~$12
Home Depot 6-32 screws ~$20
Lowes 4.5" Hole Saw ~$40
Updated 6/18/09
8x 120mm Sound Vibration Dampener $14.32
1x 24" SATA II Cable - Black w/ Locking Latch $4.25
4x Easy-Cut Polyester Expandable Mesh Sleeving 1/8" ID, 1/8" to 1/4" Bundle Dia, 10'L, Black $14.60
1x Harsh Environment Kynar Heat-Shrink Tubing 3/16" ID Before, 3/32" ID After, 48" Length, Black, Each of 48 In. (Same as 6823K29) $6.38
1x Ticn-Coated High-Speed Stl Spiral Point Tap 6-32, H3 Pitch Dia, 2 Flute $8.48
1x Metric Class 12.9 Socket Head Cap Screw Alloy Stl, M3 Thread, 10mm Length, 0.50mm Pitch, Packs of 100 $4.48
1x Black Oxide 18-8 SS Socket Head Cap Screw 6-32 Thread, 3/8" Length, Packs of 50 (Same as 96006A555) $5.37
1x Alloy Steel Flat Head Socket Cap Screw 6-32 Thread, 1-3/4" Length, Black Oxide, Packs of 25 $9.54
1x Inch Hex L-Key Short-Arm, 5/64" Hex, 2" Length $0.14
1x Inch Hex L-Key Long-Arm, 5/64" Hex, 3-1/4" Length $0.18
1x Inch Hex L-Key Short-Arm, 7/64" Hex, 2-3/16" Length $0.17
1x Inch Hex L-Key Long-Arm, 7/64" Hex, 3-11/16" Length $0.25
1x Short-Arm Metric Hex L-Key 2.5 mm Hex, 2-3/16" Length $0.14
1x Long-Arm Metric Hex L-Key 2.5 mm Hex, 3-9/16" Length $0.35
1x Black-Oxide 18-8 SS Machine Screw Hex Nut 6-32 Thread Size, 5/16" Width, 7/64" Height, Packs of 100 $5.61
1x Black-Oxide Alloy Steel Socket Head Cap Screw 6-32 Thread, 1-1/4" Length, Packs of 50 $6.74
2x Plain Steel Threaded Rod 6-32 Thread, 2' Length $1.50
1x Black Oxide 18-8 SS Socket Head Cap Screw 6-32 Thread, 3/4" Length, Packs of 50 (Same as 96006A555) $6.82
2x 1/4Watt Metal Film Resistors 1/4 WATT 390 OHM 1% $0.10
41x 1/4WATT Metal Film Resistors 1/4watt 470ohms 2% Rated to 1/2watt $1.64
10x Class 1 Ceramic Disc Capacitors - Tape/Box 50V 22pF NPO 5% Tol $0.60
5x HC49/US MHz Range Metal Can Crystals +/-20ppm 7.3728MHZ FUNDAMENTAL $1.95
2x LED Super Bright White Water Clear 7150mcd min. $2.36
2x LEDs - Thru-hole Blue 475nm 600 mcd $2.14
5x LED Standard GREEN WATER CLEAR $3.95
8x LED Super Bright T-1 3/4 GRN CLR 12DG $1.76
2x LEDs - Thru-hole Green 526nm 3000 mcd $2.38
8x LED Blue BLUE WATER CLEAR $2.32
8x LEDs Standard Blue Diffused 462nm 1500mcd $2.32
8x LEDs Standard Blue Water Clear 465nm 1000mcd $2.40
Updated 7/15/09
Radioshack: $16.54
1x Conductx™ CCFL Extension 30cm, UVgreen $2.95
Shipping $6.95
McMaster: $44.35
1x STRANDED SINGLE-CONDUCTOR WIRE, UL 1007/1569, 26 AWG, 300 VAC, RED, 100' LENGTH $6.56
1x ALLOY STEEL FLAT HEAD SOCKET CAP SCREW, 6-32 THREAD, 1-3/4" LENGTH, BLACK OXIDE $9.54
1x BLACK OXIDE 18-8 SS SOCKET HEAD CAP SCREW, 6-32 THREAD, 5/8" LENGTH $6.74
2x EASY-CUT POLYESTER EXPANDABLE MESH SLEEVING, 1/8" ID, 1/8" TO 1/4" BUNDLE DIA, 10'L, BLACK $7.30
Tax $2.90
Shipping $4.75
Fry's: $12.31
5x Linear Regulators 3A 2% OUTPUT TOL 3-TERMINAL $1.20
10x Radial Aluminum Electrolytic Capacitors - 105 Degree 470UF 10V $0.90
2x MOSFETs - Enhancement Mode N-Channel N-CHNL MOSFET ENHANCEMENT-MODE $9.90
50x .156 K.K. Connectors TERMINAL 22-26 BULK $2.50
25x .100 K.K. Connectors HSG 2P WITH LKG RAMP $2.75
10x 2.54mm M20 PC Tail Connectors 12 SIL HORIZONTAL PIN HEADER GOLD HT $3.20
50x 1/4Watt Metal Film Resistors 1/4W 39.2 ohm 1% $2.50
8x LEDs - Thru-hole Blue 475nm 600 mcd $8.56
16x LEDs - Thru-hole Green 526nm 3000 mcd $17.76
5x Heatsink TO-220 VERT MT 1 $6.00
1x Linear Regulators Positive adj Reg 3Terminal $0.43
50x Small Signal Transistors NPN/40V/100mA/4.7K $2.35
Shipping $7.52
Tax $4.76
Microchip: $18.43
2x MCP23018-E/SP $3.02
Shipping $6.78
Tax $0.43
McMaster(Second Order): $17.22
Tax $1.12
Shipping $4.75
Radioshack(Online): $17.92
1x Multipurpose PC Board with 417 Holes $1.99
1x D-Sub Pin Crimper $9.99
Shipping $6.05
Tax $1.68
Price Breakdown
Acrylic: $292.74
Total Cost of Project(Including Tools): $1966.76
1. First Post
2. This Post
3. Introduction
6. Acrylic Arrival
23. Router Tests
48. CD Faceplate
65. Photo-Shoot
Bill of Materials
Updated 5/16/09
Updated 6/18/09
Updated 7/15/09
Radioshack: $16.54
Performance-PCs: $21.87
Bitspower Anti-Vibration Ridged M3/M4 Screw Washers (Set of 20) - Black $11.97
Shipping $6.95
McMaster: $44.35
Stranded Single-conductor Wire, Ul 1007/1569, 26 Awg, 300 Vac, Black, 100' Length $6.56
Tax $2.90
Shipping $4.75
Fry's: $12.31
Mouser: $72.73
2.54mm M20 PC Tail Connectors 10 SIL VERTICAL PIN HEADER TIN $2.40
Shipping $7.52
Tax $4.76
Microchip: $18.43
MCP23S18-E/SP $3.20
Shipping $6.78
Tax $0.43
TIGHT GRIP NYLON CABLE TIE, 4-3/16"L,1"BUNDLE DIA,18"TENSILE STRENGTH,UV BLACK(50-Pack) $11.35
Tax $1.12
Shipping $4.75
14-Pin Retention Contact $5.94
Shipping $6.05
Tax $1.68
Price Breakdown
Acrylic: $292.74
Case Hardware: $217.26
Mod Supplies: $66.31
Cooling: $492.39
Computer Hardware(upgrades): $192.96
Lighting: $79.60
Electronics: $100.69
Tools: $247.26
Fees: $277.55
Total Cost of Project(No Tools): $1719.50
