Alright!
This is my first worklog. I bought my initial system about 6 months ago now. Ive decided its time for an overhaul. Well, to tell the truth my cpu shat itself pretty hard and is being replaced by intel as we speak. Not to mention, the mobo had to be sent of because the system temps where running crazy! So i thought it would be a good opportunity to change some things I really didn't like. I have decided to split up my work into a few stages.
Current pictures!
*CHECK OUT THE INITIAL SYSTEM BUILD COMPLETE PHOTOSHOOT!!*
http://www.overclock.net/intel-build...ml#post7107757
Stage 1: Finish modding case with lights, ssm and cable management. *COMPLETE*
1.2 -> Utilize further cable management with heatshrink/cable wrap
1.3 -> Exchange rear case fan
1.4 -> Murdermod sleeving installed
-> So much fun!!!
1.5 -> Paint Blu-ray drive!
1.6 -> Custom front panel for my case??? Designs coming soon!
Stage 2: Install new hardware. *COMPLETE*
2.2 -> Give each graphics card a hug
2.3 -> Initial System Complete Photoshoot!!!
- CHECK IT OUT ON PAGE 3!!!
Stage 3: Run the benchmarks and be impressed. *COMPLETE*
3.2 -> Run single gpu bench - attempt to hit 3.8, 4 & 4.2ghz stable with new cpu
3.3 -> Run SLI benchmarks
Stage 4: Buy watercooling system from Koolance and install.
4.2 -> Obtain waterfall reservoir from Cyberdruidpc from OCN.net!!
AMAZING!
Stage 5: Run the benchmarks and start to worship machine.
Now this is my system atm:
Core i7 920 @ 2.66Ghz (Broken)
Gigabyte Ex-58 Extreme
G.Skill 6gb ddr3 1600Mhz PI
Asus ENGTX 285 1gb
Corsair tx750w
V8 CPU cooler
No ram cooler
Gigabyte 3D Aurora
This is the goal:
Core i7 920 @ 4.2Ghz (Fixed!) *OBTAINED*
Gigabyte Ex-58 EXTREME -> Getting fixed under warranty.... OC'd this and the cpu to death
*OBTAINED!!!*
G.Skill 6gb ddrr3 2000Mhz Trident *OBTAINED*
An additional Asus 285 in SLI! *OBTAINED*
Coolermaster UCP 1100W *OBTAINED*
Same cpu cooler till WC system
G.skill Turbulence Ram cooler *OBTAINED*
Lian Li - Dark Armor K62 *OBTAINED*
Murdermod Sleeving Kit *OBTAINED*
Cyberdruidpc 3 Bay reservoir! *OBTAINED*
KOOLANCE Watercooling CPU-350 + 2x 285 Rev.2 Waterblocks!
KOOLNACE Pump + 3x120mm Radiator!!
REAR Mounting Bracket!!
Other random system info, using 2x 1tb western digital green in Raid 0 + a 500gb hard drive. Blu-Ray burner as well.
Im planning on getting a full Koolance watercooling system, except ill be using the EK 150 reservoir 3-BAY WATERFALL RESERVOIR from Cyberdruidpc!!!. This is alot more expensive than alot of the other kits you can get, but I really want to try it out.
I will try an provide as many pictures as possible as each of the items arrive in the mail.
The most important thing as well, any and all feedback is welcome. Ideas, thoughts, good or bad, please let me know. Alot of the ideas employed in my system came from OCN already.
Hope you all enjoy watching me build my comp
Current pictures!
Asus ENGTX 285 1gb
Corsair tx750w
V8 CPU cooler
No ram cooler
Gigabyte 3D Aurora
This is the goal:
