Ya you guessed it is a rocketfish mod. Ya another one. Well it seems that i have to cut my case up once again maybe ill add a window this time.
The main things i want to do is cut holes for cable management, mount my second mcr320 in the bottom/cut a hole in the side panel so it can it breath, and maybe a nice window. The pictures below are of my case from stock to how it is now.
The stock case with no mods
Bad angle sorry but heres the the big whole in the top on my case for the first mcr320
The case with both MCR 320 in teh bottom one needs to be screwed down. but i have L brackets that should do the trick.
Yes i know my tubing is gray. The fesser blue i was using dyed it.
