What colour should i paint the inside?
  • Textured Black
    Votes: 25 40.3%
  • Dark Metalic Blue
    Votes: 26 41.9%
  • Neon-green (something close to coolant colour)
    Votes: 11 17.7%
21 - 21 of 21 Posts
Discussion Starter · #21 ·
Originally Posted by jam3s View Post
What I would've done is put one rad up top, and the other externally mounted at the back via a rad box.
Either way, your setup looks great. I will be doing my first WC within the week. I just got my CM HAF and my MCR320, just waiting on my order from Petra's Tech.
Good luck with everything man.
jam3s
I thought about that, but then it defeated the purpose of getting the case. I ditched my modded Tempest because it had no room for a watercooling set-up that looked right. I had to chop up the front and top to get both rads to fit.
21 - 21 of 21 Posts
