So I think I have finally done it. My first case mod. Not sure what is left to do, but I have overhauled the vast majority of this case.
Unfortunatly, I didnt take pics before I did the mods to it, so I cant compare, but I took quite a few 'after' pics.
Completed So Far:
Awaiting Completion:
For the Window mod, I was thinking of something simple, not involving cutting, this case has had enough of my dremel lol. Maybe just an OCN window appliqué would do the job.
The 200mm Top fan, this is quite simple, I plan on running some LEDs into the fan to make a home made Antec 200mm TriCool. Basically, to make the 200mm fan look like the 120mms that came stock with the case. Thats the one part where this case is lacking. They include loads of fans, generate tons of airflow, pretty everything up, except for one of the biggest selling points. I intend to fix that
Custom HDD Light. This one will be fun. I want to make the ENTIRE window light up with one or more LEDs when the hdd is in use. My case is mounted on my desk, so the top panel is a pain to access, and I cannot see my hdd activity light. I will turn the top led into a power led, since this case doesnt have one, and will try to somehow transform the side window into one giant LED HDD light.
LED Feet. This project is almost done, I just have to wire it up now. See below for a screenshot of the feet. I will make a howto guide later on how to custom make these feet, but the pic basically explains it all.
If anyone has suggestions on what I can do to mod my case further (without a chainsaw being involved) please do suggest! Please no negative comments of threadjackers. Constructive criticism is welcome, as this is my first mod.
Sorry I didnt take pics of the PSU flip mod, its nothing special anyways, and would be a pain to snap a pic with this heavy beast lol...
PICS COMING SHORTLY
Completed So Far:
- 3 Cable Mnagement Holes Cut
- Cable Management Holes lined with Chrome Trim
- PSU-Flip-Mod -- 120mm Fan Hole Cut, rubber bushings left intact
- Black Spraypaint
- External Radiator Mount with Dual 80mm Fans
- Custom Window Mod (Not sure what to do here yet)
- LED Mod 200mm Top Fan
- Custom LED HDD Activity Light (Side-Window Based)
- Custom LED Feet
PICS COMING SHORTLY
