Well I might as well start a build log. Like most people I am constantly updating my system but I have finally reached a point where I'm happy with the hardware and now it's time to make my case my own.
UPDATES:
Update 1: Templates cut, placement, and new gpu cooler.
Update 2: Some layout work.
Update 3: I broke out the dremal!
Update 4: 3/5 fans installed
Update 5: 7 140mm fans in a mid tower case?!
Update 6.1: Micro Update/teaser
/Update 6.2 Sleeving Part 1
Update 7:It just got a little higher
Update 8: Preweekend update/Teaser
Update 9:Almost done
Update 10.1: Hardware arrives in installed
Update 10.2: Yummm
Update 10.3: HDD cage installed
Update 11: Knocking Off the Dust
Update 12: Just some random work to to bring you up to speed.
Update 13: Getting ready to get wet.
Update 14: Oops... That wasn't suppose to happen
Specs:
Lian Li PC A05NB
Mobo: Sabertooth P67
Cpu: i5-2500k
Cooling DD TDX water block, Magicool 420 rad, XSPC Razor 5870, MCP655,
Ram: RipjawsX 1600mhz 2x4gb
GPU: ATI 5870
PSU: Seasonic X750
Storage: 2 Intel X25-V, 2x 500gb Samsung, 250gb Samsung
So far this is the current state of my A05N. Top and side panels off and all. But this is hopefully only temporary.
I will be daring enough to squeeze 3x140mm fans in the top panel. I will be putting a 2x140mm fan setup in the bottom but that's not as daring as the top. In the top of the A05N the frame rails that just happen to be so perfectly spaced that I can squeeze 3x140mm up there with 1/16in between them.
But I already have my fans ordered and hopefully on there way to me. 5x sexy Noctua NF-p14 FLX should be arriving at my door in a week or so.
Oh I love Noctua's... My phone doesn't do the beauty justice.
UPDATES:
Update 10.2: Yummm
Specs:
Lian Li PC A05NB
Cpu: i5-2500k
GPU: ATI 5870
PSU: Seasonic X750
