1 - 14 of 14 Posts
Here is my build for the new year.
I will keep it updated but I have a busy month to come so updating may be slow.
This Is what my Build will consist of:
Case: Coolmaster HAF 932
CPU: Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz Socket LGA1366
MOBO: Gigabyte X58-UD5
HDD: 1TB Western Digital Caviar Black SATA 300 7200 rpm 32MB Cache
RAM: Corsair Dominator TR3X6G1600C7D / 6GB / 1600MHz / DDR3 (7-7-7-20,1600MHz,1.65V)
PSU: PC Power & Cooling Silencer 750 Quad (Black)
GPU: XFX 5870
Optical Drive: Samsung 22X S-ATA (SH-S223)
Lighting: 12" Quad CCFL UV Kit
Sleeving: MDPC black & orange
Cooling:
Rear Exhaust Fan: Xigmatek 140mm XLF-F1453
Rad Fans: X3 Scythe Kaze Slip Streamed Kaze 1900rpm
Rad:ThermoChill PA120.3 - 360 Radiator (15mm)
Tubing: XSPC 1/2" ID - 3/4" OD Orange/UV Orange Hose
CPU Cooler: Swiftech Apogee XT
Reservoir:XSPC 5.25" Bay Black
Pump: Laing DDC Pro Pump with XSPC V3 Acrylic Top
Barbs: Bitspower G1/4"-1/2" Silver Diamond
Thermal Paste: Tuniq TX-3
Fan Controller: Scythe KAZE MASTER ACE 5.25"
Ram Cooler: Corsair dominator cooler
As and when parts turn up I shall post an update and as I go along I will update.
TO DO LIST:
1. Decide what barbs to get (COMPLETED)
2. Paint inside of HAF 932 satin black (COMPLETED)
3. Install Side window (Undecided yet)
4. Sleeve all cables (COMPLETED)
5. Overclock system. aiming for 3.6Ghz - 4GHz (COMPLETED)
6. Change all PSU connectors to black blocks
7. Modify the pump with the solder mod to make a DDC Ultra
I am wanting to go for an orange and black theme so that is why I have opted for the Xigmatek fans/UV orange tubing & orange MDPC sleeving
Well after falling asleep instantly last night I took the photo's today.
Not the best quality and it looks like a chaos of wires but its just in the sleeving stage.
Zip ties will help me tidy them after I am done.
Hoping to get some more sleeving done today.
Discussion Starter · #13 ·
done the following tests:
Linx passed 20 runs (Fig 1)
Intel Burn passed 5 runs (Fig 2)
3D Vantage result (Fig 3)
GPU temp under full load (fig 4)
ALL temps under load are shown in realtemp and then after finishing the test I let it idle for 5 minutes and the current temp is idle temp at the time.
1 - 14 of 14 Posts
