The Throne for my Armor
Hey all I've decided to build a base (a.k.a. Throne) for my case. The main reason for this is to gain more open space in the case itself. At the moment the case is rather full. The plan is to move the radiators, pump and drain spout in the base. At the same time I will be adding 2 more 120mm radiators and moving to ultra silent fans.
Here is what the system looks like now:
Here is the design for the parts:
The material I am using is ½ inch MDF. It seems to be strong enough, although I will be adding a lot of interior support as my case is very heavy.
Here is what it looks like so far, I still have a few holes to cut and some sanding to do:
There is still a lot of work to do here and I'll keep you all posted.
Edit: BTW the fans on the rads will pull through them.
Edit 2: Changed thread name as this is a project worklog
