After a bit of research and such, I finally pulled the trigger on my water cooling build and purchased the following:
Tasks to do: (links and pictures to come)
1 Order Water cooling components
2. Setup WC Loop
3. Final WC Loop Pictures
4. Sleeve ATX, PCIE, 8 Pin, fans and misc cables
5. Lighting (Ordered!)
6. Final pics
PC Components:
ASRock Z68 Fatal1ty Professional Gen3
4x 4gb Vengeance Red
2500k (Waiting for Ivy Bridge)
Crucial M4 128gb
OCZ ZX850w Gold Power Supply
Cooler Master HAF X
2x MSI Geforce GTX 560 TI (not the most ideal due to non reference design, but its all that I got these days)
Water Cooling Components:
XSPC RX360 Triple 120mm Radiator Rev 2.
XSPC RX240 Dual 120mm Radiator
XSPC Radiator Mounting Bracket Set - 6/32 Thread
Yate Loon 120mm x 25mm Fan - Open Chassis (D12SM-12)
EK Supreme HF Universal CPU Liquid Cooling Block w/ LGA 2011 Hardware - Rev 3 - Electroless Nickel Plated (EK-Supreme HF - EN (Nickel))
EK FC Bridge Dual Parallel - SLI Connection - won't work with motherboard. Bridge is not long enough between vga cards. use the 3-SLI Dual Parallel instead. -SLI Dual Parallel instead.
EK VGA Supreme HF -Bridge Edition- Universal High Performance VGA Cooling Block - Acetal + Electroless Nickel Plated (EK-VGA Supreme HF Bridge Edition - Acetal+EN (Nickel))
Danger Den DD-CPX Pro 12V 3 Pin Powered Pump - 237 GPH (DD-CPX Pro)
Phobya Balancer 250 Reservoir - Silver Nickel (45218)
PrimoChill PrimoFlex PRO LRT Tubing 7/16"ID 5/8" OD with 3/32" Wall - Clear
PrimoChill Anti-Kink Coils - 5/8" OD Tubing - Black
IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
PrimoChill Liquid Utopia - Blood Red
Phobya HeGrease Extreme Thermal Paste - 3.5g
Microcool Chipsink MOSFET Passive Heatsink
3M™ 8815 Thermally Conductive Adhesive Transfer Tape - 2" x 2"
Bitpower G 1/4" Fittings (Qty. 8): 1/2" ID Barb
Bitpower G 1/4" FIttings 1/2" ID 90 degree Barb (Qty. 4)
WC Loop Order:
Res -> Pump -> GPUs -> 360 Rad -> CPU -> 240 Rad -> Res
Current Configuration:
Today I should be getting all the stuff, I'll be sure to post pictures along the way. Lucky for me I'm going to be borrowing my sister's camera which has a rather wide angle lens which should make for some interesting shots.
2. Setup WC Loop
6. Final pics
PC Components:
Crucial M4 128gb
Cooler Master HAF X
WC Loop Order:
