1 - 20 of 58 Posts
B.O.W
[Project]Nemesis i7 Revival
Yeeeaaaaaah!
Thats right! ~Another~ worklog for my beloved sig rig that STILL isn't finished! Alright! Maybe - just maybe - I'll finish the entire case mod this time, side panels and all for those that actually do read my logs.
This case mod is featuring 2 very special components.
First being Core i7.
Second, being Frozen Q's (OCN's newest artisan) custom T-Virus Liquid Fusion Reservoir - inspired by my all time favorite franchise Resident Evil. Nemesis in my avatar approves.
^Yes that is an actual res, non photoshoped or from the movie. Freakin awesome. All yours starting from $65 for the non-Tvirus part and up to ~$130 or so for the full T-Virus UV experience.
I've done most of it already, but I shall still update the log in parts for :turds: and giggles. Don't want to lay it all out and ruin it for those who like to actively follow work logs. That is - if anyone actually follows mine -.-
In this upgrade of my Nemesis Revived ATi is....
Intel Xeon W3520
EVGA X58 Classified
GSkill Pie (Math) Tri Memory DDR3
and of course, keeping my dearly beloved ******ed 4870x2 that doesn't seem to work correctly even after RMA. Hopefully, it was just a hardware conflict in the last build that is now being upgraded.
Final Images (not quite done but pretty much there)
B.O.W
Discussion Starter · #2 ·
Getting rid of my Asus P5Q-E and my Q6700
poor guys
dtek fuzion is staying with me
had some work cut out for me. How? I don't know. I used nothing but distilled, pt nuke, uv Petra additive, and G11.
Took me about an hour and a half to get to that, still didnt get all of it out.
put the i7 bracket on
prepping my previous T-Virus reservoir!
drilled in the bracket holes
perfecto
ABSOLUTELY FREAKIN AMAZING
Moved on the cleaning the radiator
Heading back to the reservoir I realized that I made a mistake. The pump wouldn't fit under the reservoir like I planned. So I drilled a hole and fed the reservoir output into the pump I moved beneath the flooring. Much different then originally planned
Filled the loop up just to leak test. Simply the radiator, pump and res. Freakin awesome reservoir.
More to come
B.O.W
update 2
Intel Xeon W3520 i7
EVGA Classified
Like how my number is 1337
6GB of tri memory
RAM in
Odd CPU socket - guess I'm too used to 775
CPU and barbs in
Koolance NB waterblock is nice and shiny
splat
Dtek fuzion mounted
update 3
Mobo in, if you can see it.
This was at like 5AM in the morning
4870x2
My modded Auzentech X-Fi. Sorry out of focus.
has modded oamps.
Tubing in
BAM! Testing the loop. More to come.
B.O.W
update 4
Adding Fesser Dye
Best Dye I've used. Way better then Pentosin G11
Replaced UV CCFL with Blue because the UV didn't do much for me and only took up space. The lighting is a ton better now.
Without light.
Topped it off.
Full view
bedroom lights off
Oh I forgot to mention I drilled out a T line for draining. I used a plug I bought off Petras. Not the Dtek one. I don't like those.
High resolution pictures of the resevoir. Enjoy.
Remember if you like my rig, prepare to vote for it in the July MOTM if it ever starts up. I'm going to use the delay to my advantage by maybe cutting sidepanels today or tomorrow!
For good luck try nominating my rig again here!
B.O.W
Update 5
Side panels!!!
BAM
And now I'm pretty much done.
all I need to do is buy some mesh (I think Cyber Druid has some on sale) and thats about it.
Remember - vote for me if you like this work log in the July MOTM.
B.O.W
Originally Posted by Daney View Post
Glad to see you finished reserving, was waiting to post
What are the other hardware specs? And dw, I'll be following
If I told you I'd have to kill you.
Always wanted to say that, never really was able to.
I'll be using an EVGA Classified, Intel Xeon W3520, and some GSkill Pie (math, not food pie) Tri memory DDR3.
B.O.W
Discussion Starter · #9 ·
Originally Posted by afzsom View Post
Nifty stuff. Best of luck in finishing this time around
Going to try. This time around, I have power tools that work!
I made the best hole I've ever made for my tubing. Its so neat and perfectly round. Especially compared to the shoddy drill bit I used last time that left like a massive rapture nearly several inches away.
I've never said it, I'll just have to be patient and wait for the right time
Any reason why you're going for the Xeon and not the i7 920 itself? Is it the price (Can't find that Xeon chip ANYWHERE in the UK)?
B.O.W
Discussion Starter · #12 ·
I bought the entire i7 upgrade (mobo, ram, and CPU) in 1 go from an OCN member. I was told the Xeon is just as good and someone else told me it is better but I didn't look it up.
Stepped Drill bits FTW.
The best case mods are never finished, but in a perpetual state of evolution.
GL with the build
LOL
I like that. You just got sigged.
B.O.W
Discussion Starter · #14 ·
Originally Posted by Flux View Post
I have never been sigged. Just proof there's a first for everything.
So true.
This build has now gone over 9000
Oh snap! Maybe then I shall have enough powerz to do my side panels I've backed down from doing for over a year now!
OMGOMGOMG, Wonderful res with a great build
I MUST get one of those if i go WCing
B.O.W
Discussion Starter · #17 ·
indeed you do
its amazing
and I only have it partially running
Junglist
I can't wait mate, keep us informed!
B.O.W
Discussion Starter · #19 ·
thanks I'll probably post the first update in an hour or so
1 - 20 of 58 Posts
