Links to posts:
01 - Making the Frame
02 - Good and Bad Ideas
1+ year break!
03 - Back in Action
04 - Mobo Tray and Slots
So... After 1.5 to 2 years of no modding on OCN, I've decided to come back. Some of you might remember me from the Portal case mod that won me MOTM. I haven't been on the forums for a while, but it's good to be back.
I should catch you guys up on this mod. In Dec '09, embarrassed that my Turret mod I was working on was accidentally smashed by a roommate, I decided to post my logs on Pdxlan.net. All those guys are local to me and I get to talk to them at PDXLANs whenever I go. I started this mod called Pulse^3.
The reason for Pulse^3 (pronounced "Pulse Cubed") was to create a custom mod that no one had seen before, go beyond my normal low budget, and to have a computer that is extremely easy to take to LAN parties. Think of it as a Mac for LAN parties, in that you just plug it in and turn on. No fiddling with monitors, few wires running everywhere. Something clean, but also something that fits my rougher style of modding.
The name Pulse^3 can be explained later, but for now, here's some drawings.
With this drawing, I was originally going to put four monitors on the case, but due to some measurements, it wasn't a great idea. So, I opt-ed out for something else....which you'll see later. With that, a CAD drawing was done.
Get the picture? Ok, let's get to building! ...but since this is an intro, I'll explain it in another post.
Keep reading!
1+ year break!
03 - Back in Action
Keep reading!
