About two weeks ago I picked up a wheel mouse optical for a couple dollars at a yard sale. Now, my main mouse is a deathadder, but I wanted something a bit smaller and lighter, with lower DPI, so the WMO fit the bill perfectly. However, to put it lightly, the WMO looks like absolute crap. And the switches on the one I picked up were a bit mushy. So I decided to jazz it up a bit. I know this isn't much for a true modder, but It's fun for me and the end result will be pretty cool, so I hope you guys enjoy!
btw, sorry for the phone pics.
Goals for the project:
New paintjob - Glossy red/black
Replace main switches (right/left click) with omron D2FC-F-7N
Replace cable with something thinner
Puretrak PerfectGlideHD mousefeet
Step 1: Painting
The tools. I had the black spraypaint laying around from when I played warhammer 40k, and I ran to the hardware store to find the other two cans.
Disassembly - took a screwdriver and a lot of prying to get the top off. Didn't break the clips though!
The WMO was dirty as hell, spent a good hour scrubbing everything off of it. With the mouse cleaned, Then I set to work. First was a black basecoat. Messed that up, so I sanded it down and tried again. Messed that up too. Sanded it down, tried again. Finally! But even with this, there were still a few scratches... oh well. Then a tiny bit of red accenting. Decided the mouse buttons would look better in red, so I painted them. Took some of of the design elements from this - gotta give credit where it's due!. http://tankiannam.blogspot.com/2006/12/ms-wheel-mouse-optical-new-paint-job.html
But even with the red accenting, it wasn't enough. The mouse felt empty. I needed something to put on there... A logo. But what?
Obviously this
As you can tell, the base coat was flat black. I used label sticker paper to print off a black and white OCN logo and an exacto knife to cut it out. Now for the painting! Took a TON of layers to achieve a nice solid red. Then, to keep the paint from bleeding, I took the acrylic gloss and layered it a bunch of times over the top of the shell. Final shell paint job!
Step 1: Done!
Step 2: Switches
Waiting for the switches to arrive from china. ETA: December 3rd - will post pics when they arrive, and when they're put in place.
EDIT: December 3rd, they're here from china!
2x Omron D2FC-F-7Ns (not the 10m version unfortunately... oh well. I can just pay another $3.55 and resolder if they go bad)
My current soldering iron is too thick for PCBs like this so I'm gonna have to go grab another one from the local electronics store. I'll update when they're installed.
UPDATE:
Bare PCB:
Switch size comparison:
The Soldering station: a very messy workbench haha
Omron 1 mounted and working!
My crappy soldering job (left) vs the manufacturer's (right):
Trimming the unneeded pin on the second omron. First used some standard wire cutters.
Then to get it down flush with the plastic, I used cuticle clippers like this: http://image.made-in-china.com/2f0j00QCtEDPSJbnkV/Cuticle-Clipper-CC-12-.jpg
Uh oh... damaged the PCB...
UPDATE: 12/09/12
At this point, I ordered a second WMO 1.1a off of ebay for $8. It came 2 days later. I read the guide linked at the bottom of the post, which recommended using a desoldering iron. So I ran to radioshack and picked one up. Used it to desolder the microswitches from the original WMO PCB and put them on the new one.
Workbench part 2: (you can see the old mouse's PCB in the background)
Using the desoldering iron, I have now done this much better soldering job:
Which leads to...
Finally done!
Mounted the finished PCB in the shell...
And closed it up.
The paint looks a lot darker IRL.
Step 2: Done!
Step 3: Cable
It appears that the mouse cable is soldered to the PCB, does anyone have any ideas of how to replace it/what I should replace it with?
EDIT: Idea, courtesy of MrFerrari - Zowie AM cable. Any idea where I could get one?
Step 4: Replace Mouse Feet
Mousefeet arrived today, Friday Nov. 23! Can't wait to see how they'll feel on my QCK heavy.
UPDATE: 12/09/12
Scrubbed down the original feet with 91% isopropyl alcohol to get rid of most of the goo.
Mounted the Puretrak Perfect Glide HDs:
Holy crap these are thick skates. They still glide insanely well and the LOD for this is ridiculous now.
Step 4: Done!
So that's pretty much it. As more stuff comes in, I'll be sure to update.
- eXe
More stuff:
Diogenes5's method of swapping microswitches is on page 5 of this: http://www.overclock.net/t/1216141/swapping-microswitches-for-dummies/40
Step 1: Painting
Obviously this
Step 1: Done!
Step 2: Switches
UPDATE:
Bare PCB:
UPDATE: 12/09/12
Which leads to...
Finally done!
And closed it up.
Step 2: Done!
Step 3: Cable
UPDATE: 12/09/12
Step 4: Done!
- eXe
More stuff:
