Oh hi you!
Here's my build log for Shnurok 3.0 as of last update.
In Russian, adding a suffix "ok" at the end of certain words makes it "small/smaller" than the original, hence this is me, but smaller
Make sure to post questions, comments and/or insults regarding things I've done, I'm always looking to improve!
Table of Contents:
1. Original build idea/start
2. Watercooling planning/attempts
3. CPU/GPU install
4. Waterfall res & testing the waters
5. Planning to add GPU to the loop
6. Noctua fans & DAS Keyboard
7. More planning and side view
8. New tubing, new rad, GPU block
9. Installing GPU block, putting loop back togheter
10. Future plans and new CPU block
11. Sleeving, pump top, CPU block, lapping paper & new PSU
12. Pre-cut hearthrink
13. Sleeving
14. PSU 100% sleeved
15. I got a camera & a bunch of new sexy stuff!
16. Better sleeving thanks to Lutro0
17. It's autumn
18. CyberDruid's Waterfall reservoir
19. Next update provided you by CL
20. RGB LED's are in!
21. CaseLabs has arrived.
22. Unboxing with Mammouth.
23. More sleeving, Waterfall reservoir received!
24. Lights!
25. Pump cable re-crimping!
26. Installing Watercooling and firing it up!
27. Semi-Final pictures
28. Change fans/SSD/Sleeving
Table of Contents:
3. CPU/GPU install
13. Sleeving
17. It's autumn
24. Lights!
