[Project] Silver Bullet.
12776 Views 67 Replies 19 Participants Last post by  Conspiracy
Ordered = Lian li armorsuite p80
On hand = Bitspower Black Freezer combo nb/sb water block, mosfet
Ordered = Koolance VID-428 (GeForce GTX 280/260) VGA Full Card Water Block (tri sli configuration).
On hand = water cooling components for 2 loops (2 pump, feser 360, MCR220)
Attachment 101986
Attachment 101987
Attachment 101988
I can't wait myself to get started on this project. I will not be doing any modification to the case since it's so damn expensive. (just in case if I want to sell it.)
1 - 20 of 68 Posts
Smart move with the case. Can't Beat a Lian Li.
If it's silver bullet, it should dispense coors light, perhaps project silver surfer, because it has 2 meanings, the character, and surfing the web
I'm going with silver theme internally that's why I called it that. Although, silver surfer is not bad either.
I was kinda scared tearing it apart but it has to be done. The combo NB/SB bitspower was a little tough to install, it's flat on bottom and your suppose to put a spacer between the motherboard and the chipset, plus spacer on the bottom of the motherboard. Overall it was a fun day for me
Before I took it apart.
Attachment 102225
The labor lol,
Attachment 102226
Attachment 102227
Attachment 102228
Attachment 102229
ok, my case and gpu water block are going to be here next week. for the meantime, I was eager to know if the mobo still work after all that intense installation of combo chipset. I hook it up on the case and it fired up with no problem.
Attachment 102328
Attachment 102329
Attachment 102328
Attachment 102329
Wow that loop looks CRAZY haha
I can't wait to see that P-80, but then I'll only be even more mad at myself for choosing the A1200 over the P-60 a couple months ago.. Good luck with your loop, sounds like this will be good!
yeah you should be, P80 is awesome as hell
lol, I just wrap around the tubing around the top area, cuz the apogee pump that I'm suppose to convert to mcp355 pump is not going to be here till Tuesday. Mcp355 is going to run the cpu/chipset/mosfet loop and d5 is going to handle the tri sli gpu loop.
the lian li p80 case is making me drool, I keep dreaming about it.
yes, i make love to mine on a daily basis.
ouch! aluminum hurts!
it's all in the technique
This is going to be a very nice build, Can't wait to see more pics.
lol, I'm so bored right now and did this to my cm 690 nvidia editon. I have to keep it for couple more days just in case there's something wrong with my Lian li armorsuite p80. Hurry up Mr. Brown Truck. :swearing:
1 - 20 of 68 Posts
