Well it's that time again 2 years have passed since my last build and the Coolermaster Cosmos 1000 is looking a bit tatty and I just scored a great deal on a SilverStone TJ-07 (thanks Riskitall84)
The Plan
Inverse ATX
Dual Loops
Dual IandH Stealthres 175s in the 5.25" bays
Custom front panel with windows cut out for the reservoirs and a murdermod inspired pattern
Great cable management (As little cable showing as possible)
Colour scheme is unknown ATM but I am thinking a nice blue exterior with white internals but I don't know
Table of contents
Stock photos and inverse ATX setup
MNPC feet installation
Rad stands and IandH Stealthres 175's fitted
Midpate tubing and cable holes cut and painted
Fillports and midplate fitted
Chassis primed
Chassis painted
Hardware goodies and motherboard tray painting
Case back together with res and rads
EK blocks have arrived
Pumps are in
CPU/motherboard loop done
GPU loop done
The Plan
Inverse ATX
Dual Loops
Table of contents
Chassis primed
Chassis painted
Pumps are in
GPU loop done
