you can make it easy too by cuteing regtangle and useing a rad grill to bolt on to top and bottom with fansOriginally Posted by xD3aDPooLx
It only feels like a few days ago that I finished Project Attero. Enough about that though, Lets get everyone caught up on this one.
For Starters This will be moved over to the Sponsor's Work logs soon enough. With the success of the last project at the Gigabyte ESports lan event that took place here in So Cal in June, I have been able to do this project for a few companies for a special event. I will revel that event in some time, but you all can take guess's though. I was looking to doing something completely different from what we have seen and to expand what I am able to do. The orginal plan was to go with an Orange and White theme, but I scarped that plan today. I want the theme to remain easy enough for most people to do with normal tools but still stand out. This was also the plan for the main sponsor too. Use a simple yet effective case and make a beastly looking rig with it. So with out any more delay here are some of the items I will be using
List of things to do...
- Bitfenix Outlaw case
- Intel i5 2500k
- Evga z68 SLI Micro ATX mobo
- Zotac GTX 570
- Curical Ballstix Ram 2133 8gb
- NZXT Hale90 750w PSU
- NZXT Sentry Mesh Fan Controllers
- NZXT FZ120mm Fans Non LED
- Koolance 240 - 20 fpi and 360 -30 fpi cooper rads
- Koolance 370si cpu block
- Koolance Compression Fittings
- Koolance Big Boy 80mmx240 Reservoir
- Koolance PMP 450 Pump with the PPCS adapter
- Koolance 570 GPU Block
- Big City Sleeve - Black and White
- SSD to be named later
Without further ado, here are some pics of what has came in so far.
- Cut out a place in the roof for a 360 rad and grill
- Get a custom 360 rad grill
- Custom cut window
- Order Mayhems Aurora Supernova
- Possibly paint a few items
- Cut the mobo plate and remove the HD cages
- Build it
The Bitfenix Outlaw case
The template I had for the 360 rads.. I drew it up in chalk as a rough sketch
More work will be done in a few days.. Thanks for Viewing.
