First Update! Mockup and components.
Second Update! Sanding and painting.
Mini Update New Tools
Third Update! Cutting and some tubing.
Here are a couple pix to get you interested:
The initial idea for this project was to create a small and quiet, yet powerful computer to replace my old systems. However, I recently played through Portal 2 (and Portal for a 2nd time) and realized that the color scheme was awesome. The mixture of orange, blue and white along with the goo tubes inspired me to make it water cooled and portal themed.
After researching cases and contemplating building my own like I have in the past, I decided on the Lian Li pc-q11w. I think I will aslo be adding a custom acrylic window, since it doesn't come with one.
That means that the video card can't be full length. This really posed a problem since a lot of newer performance graphics cards are full length or not reference (for full cover block). I decided that the most power I could fit and satisfy these requirements was an HD 5850. At 9.5" the card will be a tight fit, but will work.
Under the hood:
* Intel Core i7-2600 (non K, explanation to follow)
* Reference HD 5850
* 8GB Kingston Hyperx DDR3 1333
* ASrock H67m-itx board w/ wifi
* Samsung 128gb SSD
The Loop:
* 2x Black Ice GT Stealth 140 Radiatorl
* EK CPU block
* EK full cover HD 5850 and Backplate
* Swiftech MCP350 w/ Acrylic top
* XSPC 5.25" Drive bay
* Connected by UV Light blue 3/8" tubing and UV orange anti-kink coils
The point of using a non K chip: The reason is that the K chips do not have the instructions for VT-d and the purpose of the PC will be HTPC + Gaming... simultaneously and completely separate. VT-d will let me pass through the integrated GPU to the HTPC guest and the HD5850 to the gaming guest.
Everything that can be safely painted white will be and mods will be made to make sure airflow goes where it needs. This is an all internal build, so care will be taken!
The parts have been ordered, so stay tuned! Work begins next week and the PSU has already been sent out for sleeving service!
Under the hood:
* Reference HD 5850
* Samsung 128gb SSD
The Loop:
* EK CPU block
