In the past, I've made a few different kinds of wallmounts for my triple screen setup. Check out the links in my sig if you're interested. This time around, I wanted to make it as flat as possible, to get it as streamlined as possible.
First, I used some 6" wide pieces of 1/2" poplar, cut at 45 degrees, with at least an inch of flat part. One half of the 45 degree cut I bolted on the back of my side monitors...
and the other half I attached to the top of a solid board wallmounted to the wall. I used 2" drywall screws, and made sure to put felt pads on the back of the board (I pulled a bunch of paint off my wall at my last house because I skipped this step).
To make sure the 45 degree wedge on top stayed put, I put in a few screws. Gotta use a countersink to make sure the screw heads don't break the plane of the 45 degree angle and mess up where the monitor fits on top.
Now, for the middle monitor. I just used a length of the 6" board, cut at 45 degrees on both ends, and countersunk for the screws. When drilling them in, they actually went in at 45 degrees relative to the board, and at a right angle directly into the wall. Then, just use the same technique for the wedge system attached to the back of the monitor and the top of the support board.
And for the finished product. Ignore the top monitor, I used a cheap wall-mount arm for that one, just added it about an hour ago (yes, I know it's like half an inch too low). The wedges fit perfectly into each other, and the monitors lay perfectly flat against the wall. Gotta say, I'm pretty happy with this iteration of my wallmounting.
In keeping with the wallmount theme, I wallmounted my speakers and headphones, too. I love all the extra desk space.
Total for this project was only like $8 for the cost of the 4' x 6" x 1/2" poplar board. Lemmie know what yall think. Questions/comments appreciated
