1 - 1 of 1 Posts
Well, i havent figured out what my inspiration is gonna be, but i decided Im going to perform a case mod on my old 750D, so it will accept a 420 up top, and I might try another mod to have it accept a 360 in front. Or i might just do a 420 up top and a 280 in front.
Here's what Im working with right now:
My specs:
2x EVGA Reference GTX 980 Ti
i7 4790K
ASUS Z97-AR
EVGA 1000P2
I got some inspiration from a shell casing, which would fit the silver theme as well, and all I would really need is to spray the case brass, or find some brass/gold scotchprint.
Also, if i put a 420 in the case, then it would require that the brackets for the bays would need to go, which would also weaken the case structurally. So I would need to reinforce an already flimsy case with some support brackets.
If anybody has some inspiration / insight, Please feel free to share.
1 - 1 of 1 Posts
