1 - 9 of 9 Posts
What is the difference between that and the rev b? Someone is offering me that + 2x120mm Cooler Master R4 and Ultra Kaze 2krpm fans for 60 bucks and i was wondering if thats a good deal...?
Super Moderator
That is a good deal, yup. The Mega Shadow is basically a nickel-plated-black Rev.B (though it came out BEFORE the Rev.B), nothing more.
Super Moderator
Originally Posted by doc2142
Hmm, I have to get the AMD brackets? Or can i use the stock once ok?
Afaik it doesn't come with AMD brackets, you'd have to buy that separately. As it is in box it's only compatible with Intel sockets.
AMD Overclocker
Anyone know if those brackets sold locally?
Is online shopping out of the question? If not, here you go.
1 - 9 of 9 Posts
