Did anyone else have trouble installing this piece when using the 1366 holes? The two strips where you slip onto the thumb screws. It looks like the holes weren't spaced out correctly.
Mine had trouble slipping in, but the 775 holes slipped in liked butter. I exchanged it and still had the same problem but eventually worked around it with a bit of tinkering. Two other reviews I read also mentioned the exact issue.
How was your set?
How was your set?
