1 - 6 of 6 Posts
Hi Everyone, This is my first post on here!. I just purchased and installed my megahalems today. I just wanted to ask if these temps were somewhat normal or not lol. It seems just "ok" to me. Tell me what you all think and maybe something that can be improved.
Fans: dual 1800 rpm Zalman Fans, Push Config.
Case: Haf 932 (4x Antec Tricools On Side Panel)
(2x 1450 Typhoons On Top, Exhaust)
(1x 1450 Typhoon Back Exhaust Fan)
Heatsink is installed North/South Position
Intel Core i7 920 DO @ 3.8Ghz @ 1.29Vcore
My Ambient Temps are 82F (in Room)
Idle Temps = 43/44 C
Load Temp on Prime 95 = 75C Max
Load Temp on Linx = 79C Max
Retired Reviewer
51c temp over ambient. Not bad.
To get a higher OC with cooler temps, check in with i7 920 oc'ers to learn how much you can increase your Vtt so you can decrease your Vcore. Looks like you've got some more to get.
Also, if you fill in your specs we can help you better.
I Do have a profile saved for 4.2ghz My Vcore for that is @ 1.375.
But Anyways my settings for 3.8ghz is:
Vcore 1.29375
IOH/ICH I/O Voltage @ 1.550
ICH Vcore 1.12500
QPI PLL Vcore 1.2500
IOH PLL Vcore 1.8000
CPU PLL Vcore 1.8000
IOH Vcore 1.2500
CPU VTT Voltage 1.3500
DRAM Voltage 1.6500
Discussion Starter #6
I lowered my Vcore, It runs @ 1.270 When Prime95 is Running.
Upp'ed my VTT and IOH Vcore 1 Notch. Prime95 Has been running for about 1 hour now, Max Temp 76C, Been running 72C-74C Most of The Time.
1 - 6 of 6 Posts
