Prolimatech Megahalems
842 Views 15 Replies 9 Participants Last post by  OpTicaL
Just bought one online, and im afraid it wont fit with my dimm 1st and 2nd slot on my m4a79t deluxe with 2x2g corsair dominators! Anyone Know?
1 - 16 of 16 Posts
Can you link to the model of Dominators you have? You might be able to remove the fins on top of the modules.
if the ram heatsinks are flat then it should be ok.
Did you buy the am2/am3 mounting brackets too? The mega doesn't come with them.
If the distance between your cpu and dimms is the same as mine it will fit no matter how high the heat spreaders go on your ram.
edit: if your heat spreaders go to the each side of the sticks then you have about a half inch of room to play with... this again applies only if the distance between your dimms and cpu socket is the same as mine.
edit2: Dang I just saw this is for an amd build... this will probably make it more unlikely that the distance is the same.
yes i could, however it is recommended for overclocking for the first two dimm slots!
yes i did buy the am3 retention kit, thanks for the heads up though!
If it doesn't fit, you can use a nut screw to remove the top fins... but that makes the Dominator not a Dominator.
yeah Heavy, just looked at your board and you have more space than I! not sure by how much though!
Your Dominators seem to be the same as mine; you can remove the fins with a 1/32" hex key/screw and you can fit what you want there.
I'm going to piggyback on this thread instead of starting a new one.
Will the fan clips work on 38mm thick fans?
If you purchase them... the two "sets" that come wit it can only fit (2)120x25
however the part is only 2 bucks for the 38mm
Nope, I helped a friend and we had to use zip ties.
On topic, you don't stand a chance of fitting those Dominators under the Megahalems, you'll have to remove the fins (which doesn't do much, to be honest), or use the 3rd and 4th dimm slots.
Is the 38mm part available on the Prolimatech website?
1 - 16 of 16 Posts
