Proposed Micro Bomber Rig
774 8
So I was thinking Next month for the ultimate rig contest I might enter a Micro ATX build and this is what I came Up with...What are your thoughts on this? The cooler looks like it pushes the max size that will work...
NZXT Crafted Series Vulcan Black Steel / Plastic Gaming mATX Computer Case
Model #:VULC-001BK
$69.99 $69.99
ASUS Maximus V Gene LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$209.99 -$10.00 Instant $199.99
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000
$229.99 $229.99
SeaSonic SS-520FL 520W ATX12V / EPS12V 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply
$149.99 $149.99
Kingston HyperX Beast 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX16C9T3K2/8X
$59.99 $59.99
COOLER MASTER V6 GT RR-V6GT-22PK-R1 120mm DynaLoop CPU Cooler w/ Universal bracket & Dual Fan - Retail
$59.99 -$10.00 Instant $49.99
2X SAMSUNG 840 Series MZ-7TD500BW 2.5" 500GB SATA III Internal Solid State Drive (SSD)
$399.99 -$100.00 Instant $599.98
Corsair Vengeance K90 Black/Metal USB Wired Gaming Performance, MMO Mechanical Keyboard
$139.99 $139.99
Corsair Vengeance M65 Black 8 Buttons USB Wired Laser Gaming Mouse
$69.99 $69.99
2X MSI N670 PE 2GD5/OC GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
$389.99 $779.98
Subtotal: $2,349.88
1 - 9 of 9 Posts
SubZero is the Goal
The Vulcan is a good case... Handle makes the case portable... you will have room for the SLI\Xfire of your choice... cable management is lacking, but nothing a dremel cant help you with
Discussion Starter · #8 ·
Thanks for the input. I did look at whatever builds i could find floating around youtube with this case and as long as you use a modular psu its not too bad... I couldnt honestly see myself investing this kind of loot into a micro rig with a budget case but if i won it in the contest it would be pretty sweet.
If im putting my own cash into a rig though its gonna have a feature rich case like the 810 i bought.
but it was fun to design this micro beast...the other case of choice in this size bracket is the thermaltake armor a30 which seems pretty nice too but less efficient...
1 - 9 of 9 Posts
