1 - 6 of 6 Posts
Okay, so I think I did something stupid and bought a ProView 32" LCD Monitor/TV... The display is beautiful, and oddly enough, my card seems to do just fine with it. I figured it would be a problem... Do any of you forsee a problem in the future witht he same card/display configuration...?<br><br>
12ms response<br>
1366x768 resolution<br><br>
Question, do they make a dvi to hdmi adapter?
Shouldn't be a problem at all. Plus now you get to join the using a TV as your monitor club!
Oddly, when I hooked up my 55 inch hdtv, the picture was nowhere near as nice. This because it's lcd?
Well if your 55 inch TV operates at the same resolution the picture isn't going to look as nice because it is the same number of pixels used on a much larger surface.
Discussion Starter #5
ahh, that explains everything.
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16812189137" target="_blank">DVI to HDIMI adaptor cable</a>
Reactions: jcbzhnsr1
1 - 6 of 6 Posts
