PS3 on a Samsung Monitor?
1685 Views 21 Replies 10 Participants Last post by  Dman
Hi I have a Samsung SyncMaster 203b and am getting a PS3 Next Month and i need to know what cables i will need and if this set uo will work?
PS3 - HDMi to HDMi - HDMi to VGA Adapter - VGA to DVi - Monitor
any other Suggestions Welcome!
1 - 20 of 22 Posts
or i could just get a hdmi to dvi cable! DUH!!!
That's all you need. Just make sure the monitor is HDCP compliant and you'll be good to go.
what are you gonna do about the audio? is the monitor connect to ur computer too? are u gonna use the computer speakers that are connected to ur computer too?
Audio switch
~B~
im gona use the component cables from the ps3 and hook it up via headphone jack connection on my logitec speakers
oh snap this thread just answered my question well. However how do you know if your monitor is HDCP compliant?
Best way is just to look up the model # online and see.
How do you hook up your pc speakers to your ps3???
exactly, i keep asking that
audio switch?
use the component cables and get an rca adapter, then a female to female headphone adapter worked for me
audio switch?
It's a switch that allows you to put 2 or more outputs into it and plugs into one set of speakers and you can switch between which output to play.
I believe someone is selling one on here still, they're dirt cheap.
±B±
use the origanal component cables from the ps3 and get a component female to female adapter and connect a component to head phone jack or what ever cable you need
look up, i posted that already lol.
oh yeah sorry i hadnt seen page 2 LOL
BUMP any one else got any ideas
RCA Adapter....I use the built in speakers on my monitor for my 360 though.
got no built in speakers but got logitec 2.1. gona be hell connectiong that LOL
final conclusion if unsure dont waste money on cables. i spent 25 quid on cables and my monitor just goes blank. dont think its hdcp. if you looking into this make sure you have a hd compliant monitor. saves alot of money and time!
Did you try resetting the PS3's video? Turn it off, hold the on button until it beeps- probably a good 7 or 8 seconds.
I've had my PS3 hooked up to two different monitors and I've had to do that both times. Using hdmi to dvi and rca to 3.5 to hook up sound.
1 - 20 of 22 Posts
