1 - 14 of 14 Posts
hi, I have a full 1 year membership on playstation plus.i just wanted to know if a ssd hard drive will make a bigger difference over a mechanical drive as far as playing downloaded games.i have the ps3 slim with 120 gb hard drive and it is almost full.i want to install a 512gb ssd or 1 tb samsung m8(if ssd doesnt work for me).thanks in advance for your help
I took this profile pic
good luck
Some PS3 games uses texture streaming, that's where you'll see the most improvement. I have really bad pop-in when I was using the stock 80gb hdd when playing Assassin's Creed 3. I upgraded the drive to a Seagate Momentus XT 500gb hybrid, it really seem to have reduced the pop-in.
Here's someone testing Rage on PS3 with SSD.
No, a standard SSD is the best choice in terms of speed, but when I bought the Seagate hybrid, SSD prices were still around $1/gb, it was too expensive to buy a 240gb SSD, so I bought a 500GB Momentus XT instead. My rationale behind that is that most game would have less than 4GB of data per area/map, so once the map loaded, the data would be in the 4GB NAND, that would help reduce texture pop-in for games that uses streaming texture.
very informative .thank you.i have the original 120 gb in it now which is almost full do to playstation plus lol.i was looking at the samsung spinpoint 1 tb drive.i wish ssds' would come down a little more fo the 500 gb versions at least.
Shoved a spare 120GB SSD I had into our PS3 and it is much faster, install times, loading times, some 240GB SSD's are quite cheap now, I would go with one of them if 120GB won't be enough..
Honestly I think you'd be alot better buyign a mechanical drive either 500Gb or 1Tb because if you want to have a decent number of games ready to play then you need the space and if you want to download full games from the PSN store it's a must. The cost of a similar sized SSD isn't really worth the gains and with the money you save you can sign up to playstation plus and get a tonne of free games to fill your harddrive with.
Currently they have Mass Effect 3, Spec Ops and Dead or Alive 5 and they add new games each month that roll over so the cost of buying PS+ for a year at $35 and being able to play them all versus buying Mass Effect 3 alone for $35..... If you look around on the internet you can find really good deals, I just bought a year for £19.99 (RRP £39.99) so there'll be similar deals in the US.
The install times of a good mechanical over the cheap stock one is noticeable but because of the max bandwidth issues of the PS3 I don't think the SSD will give much more for the money you spend.
The texturing and filtering is really a matter of perception as when your playing on a PS3 your not expecting comparable results to a PC so pop isn't a massive concern for alot of users (myself included).
3DFX User
If you havent made up your mind yet... I would got for a Mech HDD. The reason is alot of games still need to grab things off the Blu Ray and a SSD cant speed that up. The load times will be improved because whats coming from the HDD will be faster but the BD will still handicap you to some extent.
1 - 14 of 14 Posts
